mikrotik ipsec and strongswan
I’m trying to setup ipsec between mikrotik and strongswan. Server with strongswan has one to one NAT. All, that i get in logs is:
12:16:16 ipsec,info initiate new phase 1 (Identity Protection): mikrotik_ip[500]<=>strongswan_ip[500]
12:16:17 ipsec,info ISAKMP-SA established mikrotik_ip[4500]-strongswan_ip[4500] spi:61b688aed15cdf77:76b9804f6176c4bc
12:16:17 ipsec,info ISAKMP-SA deleted mikrotik_ip[4500]-strongswan_ip[4500] spi:61b688aed15cdf77:76b9804f6176c4bc rekey:1
strongswan side:
Dec  5 12:17:26 srv2 ipsec[32066]: 10[NET] sending packet: from strongswan_private_ip[4500] to mikrotik_ip[4500] (76 bytes)
Dec  5 12:17:26 srv2 ipsec[32066]: 06[NET] received packet: from mikrotik_ip[4500] to strongswan_private_ip[4500] (92 bytes)
Dec  5 12:17:26 srv2 ipsec[32066]: 06[ENC] parsed INFORMATIONAL_V1 request 3391131250 [ HASH D ]
Dec  5 12:17:26 srv2 ipsec[32066]: 06[IKE] received DELETE for IKE_SA skynet[80]
Dec  5 12:17:26 srv2 ipsec[32066]: 06[IKE] deleting IKE_SA skynet[80] between strongswan_private_ip[strongswan_public_ip]...mikrotik_ip[mikrotik_ip]
ipsec.conf:
version 2.0
config setup
    nat_traversal=yes
    virtual_private=%v4:10.0.0.0/8,%v4:192.168.0.0/16,%v4:172.16.0.0/12
    oe=off
    protostack=netkey
conn skynet
    dpdaction=clear
    dpddelay=120s
    authby=secret
    pfs=no
    auto=add
    keyingtries=3
    auto=start
    forceencaps=yes
    rekey=no
    type=tunnel
    keyexchange=ike
    ike=aes256-sha1;modp2048
    phase2=esp
    phase2alg=aes256-sha1;modp2048
    left=%defaultroute
    leftid=strongswan_public_ip
    leftsourceip=strongswan_public_ip
    leftprotoport=17/1701
    right=mikrotik_ip
    rightprotoport=17/%any
mikoritk:
/ip ipsec peer add address=strongswan_public_ip/32 enc-algorithm=aes-256,aes-128,3des lifetime=1h secret=key
/ip ipsec policy add dst-address=strongswan_public_ip/32 dst-port=1701 protocol=udp sa-dst-address=strongswan_public_ip sa-src-address=mikrotik_ip src-address=mikrotik_ip/32 \
    src-port=1701 tunnel=yes
I will be grateful for the any help
mikrotik ros version? strongswan version?
try to increase log verbosity on strongswan side (and then on mt side) and report back
Ros version is 6.40.5, strongswan - 5.5.1.
mikrotik.log (2.92 KB)
strongswan.log (632 KB)
There are no timestamps on strongswan side.
I see Phase1 won’t go up, I also see l2tp connection starting in mt .. are you trying to l2tp over ipsec ? strongswan cannot handle l2tp directly, you need separate daemon like xl2tpd.
I would try to use ike2 as it’s more robust on nat scenario, I’ve already tested ike2 between mt and strongswan 5+ and works perfectly
Time are synchronized. I know, there is xl2tpd on server and it works fine without ipsec, it ipsec rule prevents establishe l2tp connection without encryption. I will try ike2, thank you, maybe it help.
I presume you specifically need (tunnel/encryption and) a virtual interface (l2tp) otherwise ipsec/ikev2 policy would be simpler.
Maybe you can bring up ikev2 tunnel and then place l2tp over it (2 steps, w/o mt encryption checkbox auto-create) so you can separately debug.
Now I’m not at office but asap I can provide some config snippet.. if you need
Yeah, share please your configs if you can. I already switch to ike2 and ipsec exchange are established, but there are no trafic comes after it, and I can’t get why.
I would appreciate any help on that too.
