I 'm trying to set up a VPN (IPSEC) connection between a MikroTik RouterOS and a ZyXel ZyWall (2 plus) router. Anybody tried that before? I can 't get it working.
I set up a gateway and a network policy on the ZyWall as needed (which works fine with another ZyWall router by the way).
I set up a policy, peer and proposal on the MikroTik with the same settings.
But, no answer. When I try to activate the VPN on the zywall, the logs show me no answer at all from the MikroTik. The MT is working fine for the rest, I can surf using the correct public IP-adress…
Is there a way I can check if packets are arriving and whta happens with them?
Thx,
Koen.
