Hi, from my understanding any router with IPv6 will automatically/dynamically change their MTU using PMTUD till it can reach certain websites using IPv6. But for my MikroTik, it does not seem to do so. I have to manually change the advertised MTU on IPv6 ND settings. This is my current IPv6 firewall rules, raw and address list. Is there any rules that I have did wrong? I copied it somewhere on the net.
/ipv6 firewall filter
add action=accept chain=input comment="defconf: accept ICMPv6 after RAW" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=33434-33534 protocol=udp
add action=accept chain=input comment="defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=udp src-address=fe80::/16
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=input comment="defconf: accept IPSec AH" protocol=ipsec-ah
add action=accept chain=input comment="defconf: accept IPSec ESP" protocol=ipsec-esp
add action=accept chain=forward comment="defconf: accept established,related,untracked" connection-state=established,related,untracked
add action=drop chain=forward comment="defconf: drop bad forward IPs" src-address-list=no_forward_ipv6
add action=drop chain=forward comment="defconf: drop bad forward IPs" dst-address-list=no_forward_ipv6
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1" hop-limit=equal:1 protocol=icmpv6
add action=accept chain=forward comment="defconf: accept ICMPv6 after RAW" protocol=icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept AH" protocol=ipsec-ah
add action=accept chain=forward comment="defconf: accept ESP" protocol=ipsec-esp
add action=accept chain=forward comment="defconf: accept all that matches IPSec policy" ipsec-policy=in,ipsec
add action=drop chain=forward comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
/ipv6 firewall raw
add action=accept chain=prerouting comment="defconf: enable for transparent firewall" disabled=yes
add action=drop chain=prerouting comment="defconf: drop bogon IP's" src-address-list=bad_ipv6
add action=drop chain=prerouting comment="defconf: drop bogon IP's" dst-address-list=bad_ipv6
add action=drop chain=prerouting comment="defconf: drop packets with bad SRC ipv6" src-address-list=bad_src_ipv6
add action=drop chain=prerouting comment="defconf: drop packets with bad dst ipv6" dst-address-list=bad_dst_ipv6
add action=drop chain=prerouting comment="defconf: drop non global from WAN" in-interface-list=WAN src-address-list=not_global_ipv6
add action=jump chain=prerouting comment="defconf: jump to ICMPv6 chain" jump-target=icmp6 protocol=icmpv6
add action=accept chain=prerouting comment="defconf: accept local multicast scope" dst-address=ff02::/16
add action=drop chain=prerouting comment="defconf: drop other multicast destinations" dst-address=ff00::/8
add action=accept chain=prerouting comment="defconf: accept everything else from WAN" in-interface-list=WAN
add action=accept chain=prerouting comment="defconf: accept everything else from LAN" in-interface-list=LAN
add action=drop chain=prerouting comment="defconf: drop the rest"
/ipv6 firewall address-list
add address=fe80::/10 comment="defconf: RFC6890 Linked-Scoped Unicast" list=no_forward_ipv6
add address=ff00::/8 comment="defconf: multicast" list=no_forward_ipv6
add address=::1/128 comment="defconf: RFC6890 lo" list=bad_ipv6
add address=::ffff:0.0.0.0/96 comment="defconf: RFC6890 IPv4 mapped" list=bad_ipv6
add address=2001::/23 comment="defconf: RFC6890" list=bad_ipv6
add address=2001:db8::/32 comment="defconf: RFC6890 documentation" list=bad_ipv6
add address=2001:10::/28 comment="defconf: RFC6890 orchid" list=bad_ipv6
add address=100::/64 comment="defconf: RFC6890 Discard-only" list=not_global_ipv6
add address=2001::/32 comment="defconf: RFC6890 TEREDO" list=not_global_ipv6
add address=2001:2::/48 comment="defconf: RFC6890 Benchmark" list=not_global_ipv6
add address=fc00::/7 comment="defconf: RFC6890 Unique-Local" list=not_global_ipv6
add address=::/128 comment="defconf: unspecified" list=bad_dst_ipv6
add address=::/128 comment="defconf: unspecified" list=bad_src_ipv6
add address=ff00::/8 comment="defconf: multicast" list=bad_src_ipv6
