Good day I have the following code that works perfectly on a MIkrotik KNOT for switching relays by toggling pin 4 and 6, when BLE tags are nearby, the problem that I am facing is that I can only add one MAC address to the :local addressRegex and I need multiple tags to be picked up by the knot, I already tried pipes (|) and (||) and ‘or’ logic nothing workings I even tried “;” and “,” but no luck. I also tried to only add the first 3 MAC ID’s like so :local addressRegex “DC:2C:6E” , still no tags gets picked up. Any help will be appreciate.
Regards Niel
### User params
:local missingInterval 5000
:local addressRegex "DC:2C:6E:7C:C5:04"
###Time
:global EpochTime do={
:local ds [/system clock get date];
:local months;
:if ((([:pick $ds 9 11]-1)/4) != (([:pick $ds 9 11])/4)) do={
:set months {"an"=0;"eb"=31;"ar"=60;"pr"=91;"ay"=121;"un"=152;"ul"=182;"ug"=213;"ep"=244;"ct"=274;"ov"=305;"ec"=335};
} else={
:set months {"an"=0;"eb"=31;"ar"=59;"pr"=90;"ay"=120;"un"=151;"ul"=181;"ug"=212;"ep"=243;"ct"=273;"ov"=304;"dec"=334};
:set ds (([:pick $ds 9 11]*365)+(([:pick $ds 9 11]-1)/4)+($months->[:pick $ds 1 3])+[:pick $ds 4 6]);
:local ts [/system clock get time];
:set ts (([:pick $ts 0 2]*60*60)+([:pick $ts 3 5]*60)+[:pick $ts 6 8]);
:return ($ds*24*60*60 + $ts + 946684800 - [/system clock get gmt-offset]);
:local Epomili
:set Epomili ([$EpochTime]."000")
###Bluetooth
:local adver
:local adver2
:local ts
:local clockmin
:set adver [/iot bluetooth scanners advertisements print detail as-value where address ~ $addressRegex]
:set adver2 ($adver->0)
:set ts ($adver2 -> "epoch")
:set clockmin ($Epomili-$missingInterval)
:local counterIN
:local counterOUT
:if ($ts<=$clockmin) do={
:set $counterIN 0;
:if ($counterOUT=0 or $counterOUT=null) do={
:set $counterOUT 0;
/iot gpio digital set pin6 output=1;
/iot gpio digital set pin4 output=0;
:set counterOUT ($counterOUT+1);
} else={
:log info "Tag is OUT of range! Notification was already sent before!"
} else={
:set $counterOUT 0;
:if ($counterIN=0 or $counterIN=null) do={
:set $counterIN 0;
/iot gpio digital set pin6 output=0;
/iot gpio digital set pin4 output=1;
:set $counterIN ($counterIN+1);
} else={
:log info "Tag is WITHIN the range! Notification was already sent before!"
