Mikrotik Knot LR9 LTE-M not reliable
Hey
I recently started testing the Knot LR9 vs the Ltap device with LR9 card. and I’m having very unstable connection. Just wondering if someone else has experiences the same ?
I’m 80% is network related but I have no way or at least I don’t know of a way to check signal strength on the signal as the only script I found to print these values out in the terminal requires the modem to be disconnected/disabled and since I’m logging in via this modem( when available) its an issue.
most of the info I used comes from this post
http://forum.mikrotik.com/t/knot-lte-cat-m-with-1nce-sim-card/150257/1
Device with LR9 radio. running 7.4.1 will start up and connect to LTE-M network as expected but goes offline 24 hours later and does not auto reconnect. the LTE light stays connected but Lora data is not passed on and I cannot “see” the router remotely. repeated the test 3 times keeps failing 24 hour later
Please create a support ticket:
https://mikrotik.com/support
