I use the KNOT8Kit as a LoRaWAN gateway, connected via PoE to my networt-switch.
After every reboot ( Firmware-update ) or PowerCycle (e.g. when the network-switch reboots after an update), the KNOT8 loses the LoRaWAN settings.
LoRaWAN is deactivated and the target servers are deleted in the settings.
This means that I have to log in every time, enter the servers again and start LoRaWAN.
This is quite annoying because you don’t normally notice it.
Question:
Is this possibly a setting thing that I have to set a switch somewhere in the configuration so that LoRaWAN starts automatically after a reboot or is this a firmware bug?
Thanks in advance
Firmware is the lastet version, updated yesterday
