Situation.
Server side:
SoftEther VPN server.
Running L2TP/IPSec services.
Client side:
Win7, Android, iOS clients can connect to L2TP/IPSec server with no problem.
I want to setup Mikrotik as L2TP/IPSec client.
Problem:
Mikrotik L2TP did not start L2TP tunnel succesfuly.
Log: sent control message to VPN_server_ip:1701
and nothing more happens. Looks like VPN_server_ip is not responding to control message.
What is done on Mikrotik:
/interface l2tp-client add add-default-route=no allow=pap,chap,mschap1,mschap2
connect-to=IP_OF_VPN_SERVER dial-on-demand=no disabled=no max-mru=1460
max-mtu=1460 mrru=disabled name=l2tp-BL password=1234 profile=default-encryption user=user1
Profile default-encryption is left in default configuration, no changes.
I confirm that IP of VPN server, user, password are double checked and correct.
Should I configure anything else to get L2TP part connected?
But how does it determine if the connection should be IPSec’ed or not? Maybe one time I want to establish a clear L2TP tunnel and another time pass through IPSec first?
