Mikrotik LACP (MK to Cisco)
I had a question regarding LACP.
How do I choose the Mikrotik if I want to use LACP on a layer to layer L2 or L3?
For Cisco to set up as follows:
for L2 :
Interface range gigabitethernet 2/1-2
channel-protocol lacp
channel-group 1 mode active
exit
interface portchannel 1
switchport
switchport mode access
swichport access vlan 50
exit
interface vlan 50
ip address 10.1.1.1 255.255.255.0
for L3:
exit
no switchport
How do I set RouterOS if I use LACP on L2 or L3 ?
How to configure MikroTik collaboration with Cisco LACP ?
Thank you in advance for answers
Mirek
So from your example I see that with L2 you mean attaching an IP address to a VLAN and with L3 you mean attaching it directly.
So for MT the examples would be:
/int bond add mode=802.3ad slaves=ether1,ether2
/int vlan add vlan-id=50 int=bonding1 name=bond1-vlan50
/ip addr add int=bond1-vlan50 addr=10.1.1.1/24
and
/ip addr add int=bonding1 addr=10.1.1.1/24
