I would like to know whether the MikroTik LAMP 5G R16 device supports the following routing and Layer 3 features:
Static routing;
BGP;
VRRP.
Yes it does
Thank you for your help. I can't find any evidence of this in the equipment documentation. Where can I check this?
Some questions to you that help you answer your question yourself:
What system is installed on the device: https://mikrotik.com/product/lamp_5g_r16 ?
What services the system offer Software Specifications - RouterOS - MikroTik Documentation?
