mikrotik lcd?
hello
this is my first post here in the forum
I have mikrotik mounted on a pc x86
since the version 6.22 that the LCD does not work, there is a problem with this version above 6.22
even 6:27 also does not work
may correcting this problem?
I’m sorry to hear about your issue.
Make sure LCD package is installed on your board, check /system package for presense.
What LCD module do you use?
but the LCD is installed and connected
If I install the version 6.22 it works
lcd that use is 20x4
but the lcd 16x2 also does not work
Do you have LCD package installed at /system package.
Please post exact LCD module name, that you are using.
but the package is installed
and is the name: lcd
version 6.27
called a monitor to the computer and saw that gave an error on startup
this is
loading system with initrd
starting…
could not find modulo lcddrv.ko
starting services…
with 6.22 can not appear this error
I have been looking and can’t seem to find the LCD package for v7.x for x86_64.
Does anyone know if its available? I did check and v6.x has it available.
