Mikrotik LHG LTE6 doesn't detect the SIM and blocks the internet connection
I bought a new device around 6 months back and it has had intermittent issues which required restarts. Typically, it gets resolved after the restart but since yesterday, it hasn’t been working at all.
I usually fixed the problem by “Check for updates” and “reset” but that fails saying “ERROR: could_not_resolve_dns_name”. My laptop is able to connect to the internet via my phone’s hotspot but when I connect Mikrotik device via LAN, the internet goes away and I can’t even ping 8.8.8.8 or google.com.
I also see that the interface for lte says that “no sim card inserted”. I tried 3 SIM cards and multiple resets and reboots with no help.
I have two questions:
  1. Any alternative to fix the SIM card issue? I didn’t receive any warranty (card) on the device while buying it. As a follow-up where to reach out for the warranty? I saw at multiple places that the device was defective.
  2. Why does connecting to the LAN blocks the internet which has been running with the hotspot?
I have added the details below (PFA attached pictures for the exact error). Anything else I could try or provide for a better context?
```text
[admin@MikroTik] > intercace lte info lte
bad command name intercace (line 1 column 1)
[admin@MikroTik] > interface lte info lte
     pin-status: SIM not inserted
  functionality: tx and rx rf circuit disabled
   manufacturer: "MikroTik"
          model: "R11e-LTE6"
       revision: R11e-LTE6_V025
           imei: 356662100649729
```text
[admin@MikroTik] > /ip route print
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme, B - blackhole, U - unreachable, P - prohibit
DST-ADDRESS PREF-SRC GATEWAY DISTANCE
0 ADC 192.168.88.0/24 192.168.88.1 ether1 0
[admin@MikroTik] > /ip address print
ADDRESS NETWORK INTERFACE
0 ;;; defconf
192.168.88.1/24 192.168.88.0 ether1
```text
[admin@MikroTik] > /export hide-sensitive
# jan/02/1970 00:12:36 by RouterOS 6.48
# software id = FPU9-2JB9
# model = RBLHGGR
# serial number = D8C40CBF241E
/interface lte
set [ find ] name=lte1
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip hotspot profile
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp disabled=no interface=ether1 name=defconf
add comment=defconf interface=ether1 list=LAN
add comment=defconf interface=lte1 list=WAN
add list=LAN
add address=192.168.88.1/24 comment=defconf interface=ether1 network=192.168.88.0
set allow-remote-requests=yes
/ip dns static
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
/system routerboard settings
set cpu-frequency=1000MHz
/tool mac-server
/tool mac-server mac-winbox
[admin@MikroTik] >
![ScreenShotNoSIM.png|3406x1876](upload://tMS5WA3FrAhuSnwCtHJICmwI9Of.png)
![ScreenShotInterfaces.png|3304x628](upload://q4FlmI1cO2BZnK6evVkNV04mmSA.png)
SIM card not inserted, but it is inserted and the SIM works normally on a smartphone = Broken SIM port of your MikroTik.
Sadly this is a common problem with MikroTik.
Regards.
I have had just the same problem during my first LHG setup yesterday.
It has been due to my mistake, I wrote down in to “Operator” field my operators name “tele2” and that leaded to inability to connect and “tx and rx rf circuit disabled” message. I noticed this from lte logs and error when modem is sending command and operator declines.
