Hi all,
just to understand if it is possible to let Ligowave communicate with Mikrotik devices i tried to build a PTP between an RB911G-5HPnD and a LIGO-DLB-5-20.
No particular unless you use 40Mhz. They never negotiate communication at 40: always go down to 20.
Also i didn’t find a way to create a connecton (with Mikrotik in AP mode) when using 20/40Mhz cE.
Using 20/40Mhz eC the link registered, but always scaling down to 20Mhz.
Have you ever tried to do this kind of test? Did you solved the 40Mhz problem?
Thank you for sharing your experience…
