Mikrotik limit internet bandwidth problem
Hello! I have internet with 500mb download and 30mb upload bandwidth. The problem is that when I make a bandwidth test, the download speed is limited to 250mb. When I tried with Dlink DIR-645, the bandwidth is 500/30, but with Mikrotik RB951G-2HnD the bandwidth is 240/30 and with Mikrotik RB2011UiAS-2HnD I have the same 240/30 download/upload speed. I think the problem isnțt hardware because I have the same speed with two different Mikrotik units, I think is a software problem. I repeat that with other router, the bandwidth is 500/30.
What I must do to have with Mikrotik the same internet bandwidth 500/30?
Thank you
951g and 2011 have the same cpu with such limit on nat with firewall. You are just hitting their performance limit.
Use RB 800 for wireless or RB1100AHx2 for router , your reaching CPU limitation
Ok, thank you.
