I have two WANS.
Muli 4MB (CIR)
PTCL 4MB (Shared)
i configured below but i observered traffic is going through Multi. please help me.
ip address
add address=192.168.0.10/24 network=192.168.0.0 broadcast=192.168.0.255 interface=Local
add address=X.X.X.150/29 network=X.X.X.144 broadcast=X.X.X.151 interface=MULTI
add address=192.168.1.10/24 network=192.168.1.0 broadcast=192.168.1.255 interface=PTCL
/ip dns set allow-remote-requests=yes cache-max-ttl=1w cache-size=5000KiB max-udp-packet-size=512 servers=8.8.8.8
/ip firewall mangle
add chain=input in-interface=MULTI action=mark-connection new-connection-mark=MULTI_conn
add chain=input in-interface=PTCL action=mark-connection new-connection-mark=PTCL_conn
add chain=output connection-mark=MULTI_conn action=mark-routing new-routing-mark=to_MULTI
add chain=output connection-mark=PTCL_conn action=mark-routing new-routing-mark=to_PTCL
add chain=prerouting dst-address=X.X.X.144/29 action=accept in-interface=Local
add chain=prerouting dst-address=192.168.1.0/24 action=accept in-interface=Local
add chain=prerouting dst-address-type=!local in-interface=Local per-connection-classifier=both-addresses-and-ports:2/0 action=mark-connection new-connection-mark=MULTI_conn passthrough=yes
add chain=prerouting dst-address-type=!local in-interface=Local per-connection-classifier=both-addresses-and-ports:2/1 action=mark-connection new-connection-mark=PTCL_conn passthrough=yes
add chain=prerouting connection-mark=MULTI_conn in-interface=Local action=mark-routing new-routing-mark=to_MULTI
add chain=prerouting connection-mark=PTCL_conn in-interface=Local action=mark-routing new-routing-mark=to_PTCL
add dst-address=0.0.0.0/0 gateway=X.X.X.145 routing-mark=to_MULTI check-gateway=ping
add dst-address=0.0.0.0/0 gateway=192.168.1.1 routing-mark=to_PTCL check-gateway=ping
add dst-address=0.0.0.0/0 gateway=X.X.X.145 distance=1 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=192.168.1.1 distance=2 check-gateway=ping
add chain=srcnat out-interface=MULTI action=masquerade
add chain=srcnat out-interface=PTCL action=masquerade
