Mikrotik loadbalancing upto 4 different internet links
I need help loadbalancing the 4 different internet links I have. Please advise.
more details.
do you NAT all clients or give public IPs?
If you NAT, then you can load balance on the edge router. If you don’t, then you will be stuck with using a single gateway unless you get an ASN and do BGP, then you still would have to manipulate your AS path and you wouldn’t be getting instantaneous load balancing.
With 4 connections I assume DSL?
