I have a RB750GR2. I am very satisfied with the device. The router has a fixed IP address on the WAN side (no DHCP client) and on the LAN side also only fixed IP addresses (no DHCP server). But only one problem I could not solve:
The client PC’s use the Mikrotik router as a DNS server. That everything works. But about 24 hours after the router reboot, the DNS resolution for the client PCs does not work anymore. After restarting everything is running again. I’ve searched the forum and tried all the tips, but without success.
What can be the problem? I really do not know anymore.
I am pleased about each tip that solves the problem.
I would say that the router has forgotten the dns server obtained in dhcp message from server. It is a bug I reported during the times to mikrotik several times and they solved it and then broke it repeatedly. Just set the dns server in the router manually until they solve it finally. Looks like 6.33 and 6.34rc are somehow fixed regarding this problem.
@capprentice:
The device is cold. As workaround I can test a schedule-service to delete the DNS cache.
Yes, I think also that the router has forgotten the DNS server. But I have registered the DNS server fix (static WAN-IP) and no DHCP. The RouterOS is version 6.33 and the firmware 3.27. I hope the next firmware version the problem has been considered.
@hgonzale:
How can I switch the DNS server on/off?
Here the nslookup:
D:>nslookup www.google.de
DNS request timed out.
timeout was 2 seconds.
Server: UnKnown
Address: 192.168.1.1
*** Zeitüberschreitung bei Anforderung an UnKnown.
