Mikrotik Log Transfer to other Mikrotik
Hello
That would be a bad way of doing it. The better approach is to install a syslog server.
With the server, you won’t lose your old logs if the power falls. You can backup a server, increase disk space. You can also run scripts to analyze you data.
Cheers
Sent from Tapatalk
BTW, no it can’t be done.
Sent from Tapatalk
