I am using Iphone 6 and facing frequent problem with mikrotik login redirect not working.
Kindly help.
Kindly help.
Do you mean its not redirecting to the hotspot login page?
If so, you can reset the HTML if you goto ip → hotspot
Try assigning one dns name to your hotspot and use ssl certificate to bypass redirect
