Hi normis
I suggest putting mikrotik logo on a head bar of winbox
owners of Eee PC will damn you =)))
well well !!
then on blue side bar, mikrotik deserves that
some people don’t like to see any reference to mikrotik on their winbox. they use it for their custom product. we won’t build many versions of winbox ![]()
tons of people don’t like to see the logo in the indor cases either : P
Why this change now? from pretty black to logo? It’s terrible..
Why can Dell put their name on the laptops, and we can’t put our logo on our products?
We also have the MFM program, you have now the ability to order different kind of cases.
Dell sells their equipement mounted and ready to use. We have to mount the cases, usually..
But yes, every company could make this. I don’t say you can’t.. I only say that tons of people don’t like to see the logo in the indor cases.
Just a constructive criticism.
As I said, if you anyway have to assemble them, you can choose where to buy the cases. Some people even prefer other manufacturer case solution as they can be customized to their needs
