Mikrotik Lte product with IPPBX (3Cx)
dear all
Is there anyone using or
Is it possible to use Mikrotik lte product as gsm modem with IPPBX or 3Cx for voip calling.
Its hard to find gsm usb dongle
I’m not sure I understand what you actually need.
  • You can use a Mikrotik LTE product to provide an internet uplink to your IP PBX, allowing it to establish a trunk connection with a VoIP operator over IP, using the data service of the mobile network.
  • You can not use the Mikrotik LTE modem to provide a voice mode connection, where you would send the number dialling commands and audio stream to the LTE modem to deliver them using the voice service of the mobile network.
