I have a mikroTik mAP lite. https://mikrotik.com/product/RBmAP2nD
This router only Supports 2.4GHz band. Is there also extra tiny router which also Supports 5GHz?
Thank You!
Thank You!
maybe better this, which can work at both at the same time:
https://mikrotik.com/product/RB952Ui-5ac2nD
Thank you for the answer. This is too large i need a small one.
