Can I use the mikrotik metal 2shpn as a router?
This is the scenario:
PPPoE ADSL <=> 2shpn <=> WLAN Clients
So the 2shpn will connect to my ISP via PPPoE and then route internet to its wifi clients?
Thanks in advance for the guidance.
Since it runs RouterOS like any MT device (except RB250/260 switches which use SwOS), you can do anything with it.
Just be careful not to be locked out when configuring the ethernet port as WAN while configuring it via wired connection ![]()
