Mikrotik MPLS = Cisco MPLS???
i am doing some study, before go thought that…
just would like to know, Cisco MPLS have how many type???
and, it’s the mikrotik RouterOS support what Cisco can perform???
if yes, can one side i use the Cisco and the other end Using RouterBOard?
any issue with this???
thanks…
Yes MPLS is an open standard and can be used with any Cisco router that supports LDP - which is just about all MPLS capable Cisco routers.
Ive used mikrotik routers on a multi state carrier mpls network with no issues
Hi, as a lot of vendor said Cisco MPLS was different than Mikrotik MPLS.
i get confused on this, as they claim said, Cisco support multi BGP but Mikrotik no…
what’s does it mean?
The other thing is, is the Wireless MPLS setting is not the MPLS as what Routerboard can do???
RouterOS does support multi protocol BGP. It also has compatibility with Cisco.
You can read more on the wiki:
http://wiki.mikrotik.com/wiki/Manual:Cisco_VPLS
http://wiki.mikrotik.com/wiki/Manual:EoMPLS_vs_Cisco
Hi Mrz,
MPLS is one of the standard and the VPLS is another standard???
as can see, most guide here the MPLS setting must with VPLS…
so confused on it.
VPLS is the tunnel over MPLS cloud to connect remote sites.
hi mrz,
after study around, understand that can be different standard of tunnel drive on top of the mpls like vpls is one of it.
now is, can be the RouterOS {Routerboard} setup only mpls to peer with PE router like cisco brand?
Your question was already answered. YES, Cisco MPLS = MikroTik MPLS
Dear mrz & normunds…
now understand already, thanks and appreciated…
