I have attached a map of the test network. It is the ring in the lower right corner.
One out of 5 routers I setup with MPLS doesn't respond to Winbox well after enabled. I can ping it, I can telnet into it, but I can't Winbox into it. Once I disable MPLS, all is well. Below is the MPLS export for the failing router. To the best of my knowledge I followed the directions on the wiki.
Hammy, MPLS as such does not directly affect any application - be it winbox, telnet or anything else. The information you have provided about your network is not enough to figure out where the problem could be - you should start by figuring out if winbox connection gets to the router, whether response traffic can get through and such.
Just imaging possible causes, the first that comes to mind (assuming you really can ping and telnet to the same router address that you try to connect with winbox) - if you are doing some NAT and running MPLS bypasses that NAT.
/mpls ldp set enabled=no, everything works just fine.
/mpls ldp set enabled=yes, I cannot Winbox. When I telnet or mac-telnet in, I cannot issue a print command anywhere. I can’t disable a port on a bridge.
There is low CPU usage 5% or less, but those commands will not work until I disable LDP.
It’s just like the router can’t do anything complex when MPLS is enabled.
I don’t know about “normally”, but the regular package is on a feature freeze. It works fine, but all improvements and fixes are going into the “test” package.
I sent it in on the 18th. I submitted more information (saying that the test packages didn’t help at all and the supout showing that), but haven’t heard anything.
Thank you for report, we will check and try to fix this issue.
Currently you can remove or disable manually added LDP neighbors which has send-targeted=yes and winbox should work fine.
Hammy, it is highly possible that your problem is caused by some link in your setup not supporting the MPLS MTU that is configured (default value is 1508), can you elaborate on what type of hardware you have in path between host connecting with winbox and router? You notice this with winbox because it starts sending max size packets (that are not generated when using telnet or regular ping).
Anyway, thanks to your report, issue with MPLS implementation has been identified (and will get fixed in upcoming 3.18) - when router originates packets, it (mistakenly) considers that path MTU is MPLS MTU (1508 bytes) minus label stack size (4 bytes), not interface (layer 3) MTU as it should. With this problem router prepares 1504 byte winbox connection packets (which should not be fatal, but is still wrong).
Even with this fix - MPLS MTU should be configured properly so that it does not exceed the abilities of hardware. If there was no this problem - probably you would never experience this, because winbox would prepare 1500 byte packets, resulting in 1504 bytes with MPLS label and probably your hardware can handle that. But you would get in trouble as soon as you tried to use some other MPLS application that adds more than one label.
