This is a Cacti template for measuring CPU load of Mikrotik multi-core RouterBoards
Graph templates:
Mikrotik - multicore CPU load (avg) - shows min, max and AVERAGE of the CPU load
Mikrotik - multicore CPU load (sum) - shows SUM of all CPUs load (splitted into 4 groups)
Note: Both templates are similar, just graph presentation differ.
OID used:
cpu_load .1.3.6.1.2.1.25.3.3.1.2
Installation:
- copy mikrotik_multi_cpu.php to <path_cacti>/scripts/ (mostly /var/www/cacti/scripts/)
- import cacti_graph_template_mikrotik_-multicore_cpu_load_avg.xml and cacti_graph_template_mikrotik-_multicore_cpu_load_sum.xml from Console=>Import Templates
- add graph for your device (Console=>Devices=>Create Graphs for this Host - Mikrotik - multicore CPU load)
