hello everyone.
i’m not that good with mikrotik so i have a simple question for someone, and a not simple question for someone like me
if anyone can find the time to respond, here is my question
i have 4 internet connections from 2 diferent ISP
2 x 1 cable modem connection 4 Mbps/1Mbps
2 x 1 adsl connection “ppoe” 8 Mbps/768 kbps
i have “RB750G” 5 port.
WAN1- 192.168.1.2 > 4 Mbps/1Mbps “already conected "
WAN2 - 192.168.2.2 > 4 Mbps/1Mbps “already conected”
WAN3 - 192.168.3.2 > 8 Mbps/768 kbps " PPPoE Client” bridge mode
WAN4 - 192.168.4.2 > 8 Mbps/768 kbps " PPPoE Client" bridge mode
LOCAL - 192.168.0.1 LAN
conected clients will be from 30 to max 40 , loadbalancing + failover
can you tell me if this is possible , and if yes. always if you find the time to tell me how.
Thanks.
DRep
May 1, 2013, 5:40pm
2
PCC is not very good with un equal links.
ronix
May 4, 2013, 5:40am
4
1st of all you will not have a 100% load balancing with different ratio of links …
try to send traffic twice to WAN3 & WAN4
where:
WAN1 per-connection-classifier=both-addresses-and-ports:6/0
WAN2 per-connection-classifier=both-addresses-and-ports:6/1
WAN3 per-connection-classifier=both-addresses-and-ports:6/2
WAN4 per-connection-classifier=both-addresses-and-ports:6/3
WAN3 per-connection-classifier=both-addresses-and-ports:6/4
WAN4 per-connection-classifier=both-addresses-and-ports:6/5
but as you say your up are different in the 2 links and it is lower in WAN3 & WAN4 …
so if you have a high traffic in up way then i think you will see a bottleneck in the up stream in WAN3 & WAN4 …
send traffic twice to WAN3 & WAN4 , will try this
hussan
May 10, 2013, 12:53am
6
i m trying load balancing with 2 wan but the issue is my routa wan 2 in not working distance 2 color in blue tell me what can i do please
ronix
May 11, 2013, 7:02am
7
hussan:
this is normal the priority is for distance 1 if it is down then distance 2 will work..
can you see any traffic in interface ?
everything works great got all 4 wan’s from same isp,
anyone knows whats the best router board that can do load balancing at best ?
it’s depend on how many connections, filters, queue, routeur have to manage …
regards
mikb262
September 27, 2015, 3:12pm
10
hey
i m using 8 link of dsl 12mb dload & 1mb upload each
what model of mikrotik is best for me
plz repply
