At we speak I have a simple setup using Mikrotik and one UBNT Unifi AP. This setup contains 3 SSID’s, and each SSID uses an other DHCP range:
- SSID : IT2GO Private – VLAN : 101 – DHCP range 10.101.0.0/24
- SSID : IT2GO Trusted – VLAN : 102 – DHCP range 10.102.0.0/24
- SSID : IT2GO Public – VLAN : 103 – DHCP range 10.103.0.0/24
The AP is connected to port 4 of a RB2011UAS and everything works great.
Now i’ve bought a new UBNT Unifi to install into my house (at port 5 of the RB2011UAS). I want it to use the same VLAN’s, DHCP ranges and SSID’s so i can roam between them with eg my smartphone.
What do i have to change in this setup? Do I have to create a bridge between the VLAN’s on port 4 and 5 so both can use the same DHCP server (and I have the same IP address, no mather if I use the first or second AP) or do I have to make other changes?
My configuration (export) is on Pastebin : http://pastebin.com/jt4tj2TV
I hope you guys can help me with this issue ![]()
