Mikrotik + Munin
I am not able to generate the graphs for node Mikrotik
happens the following error:
2013/10/13 12:30:00 [FATAL] Socket read from repetidora.clickmar.com.br failed. Terminating process. at /usr/local/lib/perl5/site_perl/5.14/Munin/Master/UpdateWorker.pm line 254
repetidora.clickmar.com.br = Mikrotik
a simple host tree
[devel.mar.com.br]
address 127.0.0.1
use_node_name yes
[repetidora.clickmar.com.br]
address 187.94.124.5
1 )
FreeBSD devel.mar.com.br 9.1-RELEASE-p7 FreeBSD 9.1-RELEASE-p7 #0: Wed Oct 9 01:21:31 BRT 2013 root@devel.mar.com.br:/usr/obj/usr/src/sys/CUSTOM i386
munin-common-2.0.17 Common components between a munin node and server
munin-master-2.0.17 Collector part of Munin
munin-node-2.0.17 Node-specific part of Munin
2 )
root@devel:/var/log/munin # telnet localhost 4949
Trying 127.0.0.1...
Connected to localhost.
Escape character is '^]'.
munin node at devel.mar.com.br
nodes
devel.mar.com.br
list repetidora.clickmar.com.br
mikrotikwirelessconnected_repetidora.clickmar.com.br
fetch mikrotikwirelessconnected_repetidora.clickmar.com.br
cl_on_wlan1.value 34
cl_on_wlan2.value 1
cl_on_wlan2.value 1
3 )
2013/10/13 12:30:00 [INFO]: Starting munin-update
2013/10/13 12:30:00 [INFO] Process 79728 is dead, stealing lock, removing file
2013/10/13 12:30:00 [INFO] starting work in 80035 for repetidora.clickmar.com.br/187.94.124.5:4949.
2013/10/13 12:30:00 [INFO] starting work in 80034 for devel.mar.com.br/127.0.0.1:4949.
2013/10/13 12:30:00 [ERROR] Munin::Master::UpdateWorker<clickmar.com.br;repetidora.clickmar.com.br> died with '[FATAL] Socket read from repetidora.clickmar.com.br failed. Terminating process. at /usr/local/lib/perl5/site_perl/5.14/Munin/Master/UpdateWorker.pm line 254
2013/10/13 12:30:00 [INFO] No old data available for failed worker clickmar.com.br;repetidora.clickmar.com.br. This node will disappear from the html web page hierarchy
