Mikrotik network
Hello
I have more than one Mikrotik network and each network has a connection from a private server
When I want to access a remote network, reconnect to a VPN … and it works
But I would like to connect more than one private network through Mikrotik and control from one place
is there a solution ?
Sure there is, but if I understood right what you’re asking, you need VPN tunnels between the Mikrotik on that “one place” and all of those remote networks; if some of those remote networks use overlapping IP subnets, it adds an extra layer of complexity to the task.
To get a more useful answer, please ask in a more useful way - a drawing might be better than words as I’m not certain whether we use the same subset of English. E.g. I haven’t really understood what you mean by “private server” and what is its role in the currently existing topology you use.
