mikrotik newbie settings
Hy all! I’m newbie in MikroTikOS, and I’ve got a few questions..
(firs of all, srry for my weak english)
I’ve got a little complex configuration, :
1 cable modem (DHCP from my ISP)
1 Linksys Router ( connected into the cable modem)
this configuration still alive and working. the workstations connecting into the Linksys router via Ethernet cable, getting 192.168.0.x ( 100-150 ) IP, and connecting into the NET.
i’d like to connect a mikrotikOS router-PC into this system, to separate another 10.0.0.x IP range, for a few workstation.
i’ve installed a mikrotik 2.9.6 lvl6 OS into a PC, and connected 3 ethernet card.
  1. ethernet: name: config : IP: 192.168.1.150 (fix) connected into the Linksys router.
    i’m configuring the mikrotikOS via this enternet adapter.
  2. ethernet: name wan : IP dinamic ( getting dinamic IP from the Linksys router 192.168.1.x)
  3. ethernet: name lan: DHCP server ( i’ d like to serve 10.0.0.x IP address via this adapter) range ( 10.0.0.2-10.0.0.254 )
i’ve set up the ethernet interfaces, and a DHCP client into the interface (name: wan) adapter. & i’ve set up a DHCP server into the interface: (called lan).
Interfaces:
DHCP Server:
DHCP Client interface:
How can i set up the mikrotikOS, to serve NET into the 10.0.0.x clinets ?
please upgrade to 2.9.28 as there is a problem in your version
is there a way to upgrade w/o interuption and reconfiguring ?
just upload packages via ftp and reboot. takes less then 2 minutes.
how can i update my configured routerOS?
i’ve downloaded the “routeros-x86-2.9.28.npk” file, from http://www.mikrotik.com/download.html.
how can i transfer this file into mikrotikOS? i’ve started winbox, logged in, and found → system → Auto Upgrade menu, but how can I use this?
lazy lazy lazy …
http://wiki.mikrotik.com/wiki/Upgrading_RouterOS
thanks the link, but as you can see, of my firs post, i’m not a lazy man, just this link escaped my attention. anyway i’m updated my routerOS, but nobody can answer my original question,: “How can i set up the mikrotikOS, to serve NET into the 10.0.0.x clinets ?”
You at least have to configure NAT/masquerading, like this:
/ip firewall nat add chain=srcnat out-interface=wan action=masquerade
And you don’t assign a DNS server to your clients, so I suppose you will have a hard time doing anything with name resolution - i.e. practically everything.
Best regards,
Christian Meis
