mikrotik newbie
Hello
am newbie in mikrotik i wanna some help if u plz
i have installed mikrotik and have connection from pppoe
i maked everything good i guess all users can login to my server but nobody can browse any website or use any messenger and this is the configuration i made
[admin@MikroTik] > interface print detail
Flags: X - disabled, D - dynamic, R - running
0 R name=“Lan” mtu=1500 type=ether
1 R name=“Internet” mtu=1500 type=ether
2 R name=“pppoe-out1” mtu=1480 type=pppoe-out
[admin@MikroTik] > ip address print detail
0 address=10.2.2.1/24 network=10.2.2.0 broadcast=10.2.2.255 interface=Lan
actual-interface=Lan
1 D address=172.16.50.166/32 network=172.16.50.1 broadcast=0.0.0.0
interface=pppoe-out1 actual-interface=pppoe-out1
[admin@MikroTik] > ip pool print detail
0 name=“pppoe” ranges=192.168.0.1-192.168.0.55
[admin@MikroTik] > ppp secret print detail
Flags: X - disabled
0 name=“new” service=pppoe caller-id=“” password=“new” profile=default
local-address=0.0.0.0 remote-address=0.0.0.0 routes=“”
[admin@MikroTik] > ppp profile print detail
Flags: * - default
0 * name=“default” local-address=pppoe remote-address=pppoe
session-timeout=0s idle-timeout=0s use-compression=no
use-vj-compression=no use-encryption=no require-encryption=no
only-one=no tx-bit-rate=0 rx-bit-rate=0 incoming-filter=“”
outgoing-filter=“” wins-server=0.0.0.0
[admin@MikroTik] >
hej
am new mikrotik user well no body here for help
duuhhh
i am facing the same problem but still no body tring to help…
Ip firewall source nat and then masqurade. read theat damned manual. I1m a newbie too, but I read the papers and ask after it. More usefull that ask the same question that is writen down.
not for bad, just for learn.
i read all the manual but i didn’t know the problem :frowning: :frowning:
So can u tell me wut i did wrong
U have to use source nat and masq. to hide your lan from internet and to translate all the requests from your la to internet. Read that part “Source nating” from manual. -all desribed there.
Whats the default gateway for your MT and Ip address for it which in same subnet on that gateway? U have ‘Internet’ interface but not configuring it yet.
so you wanna create a pppoe server on your mikrotik machine!
let’s start from the begining. and I prefer to reset your MT to have a clean and clear configuration…
after reseting the router we have some easy steps to do to complete our
mission.
1st: enable only 2 interfaces { one for internet and the other one for customers }
2nd: configure the IP and DNS for the internet interface by adding an address on ip address add address:x.x.x.x/x interface:internet
add dns on IP DNS add primary-dns:x.x.x.x Secondary-dns:x.x.x.x
after that we have to create a range of ips dedicated for pppoe server
go ip pool add range:x.x.x.2-x.x.x.x interface:customers name:mypool
3rd jump to: interface pppoe-server server add service-name=“X” interface=customers mtu=1400 mru=1400 authentication=pap,chap one-session-per-host=yes default-profile={this name must be the profile we’re gonna create on ppp profile } so we’ll modify default-profile when we create the profile on ppp section.
4th jump to ppp profile then type add name=“x” local-address=x.x.x.1 remote-address=“range we have created in the ip pool” simply click tab n it will appear… only-one=yes incoming-filter=input outgoing-filte=output
here we just done!! so all u need is to create a username and pass on ppp secrets add name=x pass=x profile=x !! go ahead and try it !!:slight_smile:
good luck :slight_smile:
