Read our latest newsletter and learn more about:
• The new features of the latest RouterOS 7 BETA release
• netPower 16P
• LDF LTE6 kit
• GPEN21
• Wireless Wire nRAY
• Even lower prices for CWDM
• An in-depth review of our CCR1009-7G-1C-1S+
Newsletter_96.pdf (3.62 MB)
https://box.mikrotik.com/f/63051ba3645d4faf9d2b/?dl=1
Hi
Any news on the availability of the nRay?
regards
Peter
Still no LHGR XL with 1GbE with M.2 - we wait at that series of SXTR/LDF and new D53iGR without wifi to replace M11G & M33G !
When RouterOS 7 officially gets released, will the speed test results be updated for v7? Or will speeds be posted for both v6 and v7?
the latest Linux Kernel 5.6.3 featuring new up-to-date
driver and security options
Does this mean in ROS7 are also new/improved Wifi drivers used?
By the way, what about some Wifi 6 product announcements?
Currently v7 has the same WiFi drivers.
Hi Normis, is it legal to product the next mouth watering newsletter, when the hapac3 is not even yet in the product list on the website under product listings??
Anav, clean your glasses, I think it is here under LTE devices : ![]()
https://mikrotik.com/product/hap_ac3_lte6_kit
Hi Weiwei, I stand corrected, it being a hapac wifi device I was looking at wifi devices for the home. Perhaps if I may be permitted to ask it to be located in two different spots on the hardware pages.
+1 for WiFi6
Should we expect to see a wAP ac2 soon with WiFi6 or alternatively specs similar to Audience and with higher gain antennas – 3.5 - 4.5dbi for 2.4Ghz and 4.5dbi for the 4x4 5.8Ghz with similar or better receive sensitivities. There could be potential applications for an ‘outdoor Audience’ with similar meshing capabilities.
+WIFI6 and an updated WAP AC model!! [Wap AC2??]
I really enjoy the WAP AC [RBwAPG-5HacT2HnD-US]. But really could use better wifi gain and sesnativities. As 5Ghz drops off very quickly, short distances. I have a few deployed and will continue to purchase.
The CAP AC model I had to return those.. Ran way too hot with the ARM CPU’s and brick themselves.. WAP AC model is superior [can also use outside!]
MikroTik doesn’t give us any idea about Wi-Fi6. The subject is MikroTik employee Normis, but does not respond to its own forum members. I don’t think this has a logical explanation.
At least, MikroTik needs to share its road plan for Wi-Fi6 with business partners. We must share with us what he thinks about this subject and what he will do so that we will know whether we will have to use the products of different brands.
FYI - I just ordered and received a new wAP AC device, seems it was recently revised??? Included a new GBPOE injector. No more rubberized feel [new look is dark gray and white] and input voltage is now to -57v [prior were 48v].
box had new sticker ‘X001A2AHLF’ RBWAPG-5HACT2HnD
What is going on?
It always accepted 11-57V
Just making note the included POE injector is different design and markings on it. Need me show a picture?
None of the new MikroTik newsletter depicted this GBPOE adapter. Also the wAP Ac box had a ‘NEW’ sticker. So perhaps a change from MikroTik?? or fake??
I thought it was about the RB itself - the color and input voltages.
So the injector is all that has been changed?
I like the look and prices of the CWDM hardware ![]()
that is appeears to be true. Powered up the wAP AC and all appears normal. Same CPU speed, specs, etc.
Only POE injector updated to better model. That is all. Please keep to the topic. This topic is about newsletter!
Hi Normis we love the CWDM stuff as its allowed to expand some of our old 4 core SM runs to run some offices directly and avoid piggy backing on other offices for data uplink.We had to import cwdm equipment directly before and it usually arrived late and sometimes faulty.Dealing with a credit card with big amounts such as that was a nightmare.
Any chance you guys might look at higher capacity 16 CH units ?
Also good on you guys for hopefully improving those POE injectors , I’ve had lots of them die in the field . I just wish you guys would rather follow Ubnt style design of the injector as it avoids that terrible barrel connector , and the thin wires look very unneat without velcro/cable tying everything down.
