Hi
I have setup a router board 3 port LAN
with the following
Ether 1: ADSL connection
Ether2: DHCP server - main network
Ether3: Wireless internet connectivity
I am having trouble accessing either network via ether2 but i can ping both ether3 and ether1 from a pc plugged into ether 2
Any idea’s ???
Regards
Malcolm
In the firewall rule try to allow the other 2 networks and see what happens. Make sure the rule comes B4 the drop rule.
Ben
OK
But should it just not work without any firewall rules or do you specifically need to create those rules
Regards
Malcolm
djape
May 11, 2005, 8:15am
4
Well, you must give us more details…
OK
Router has 3 ether ports
No extra config
1 ether does PPPOE dial up.
1 Ether connects to ADSL modem.
1 Ether to main network.
No firewall rules created.
External network is pingable via miktotik console but not via Lan connected.
Tried creating Ether bridge - didn’t help.
Any idea’s ??
Regards
Malcolm
First, drop all drop firewall rule, and make sure that the default is allow/accept.
Then try to ping from a machine that is in same subnet with the interface host the ip you want to ping. If this work, it means your interface setting works fine, and maybe there is routing problem.
djape
May 19, 2005, 2:56pm
7
When you said you don’t have any firewall rules I hope you didn’t count firewall src-nat rule?
There must be a IP route etc…
You should consult manual, cause againg not giving any details i can only assume that you don’t have a clue about networking (no offense).
Cheers…
