It would be interesting if Mikrotik was to so this type of test:
AP with many wireless clients
Saturate the wireless traffic from the AP to all clients (then later reverse the direction and test again)
Connect an oscilliscope to the AP antenna (or a seporate tuned antenna next-to/close-to the AP antenna). Or connect it to a test point to be able to see TX and RX traffic.
Look at the oscilliscope for dead nothing-happening time periods.
Then overlay those dead silent time-periods with a what is happening at that moment.
Also , overlay the time-periods of 6-Meg connection rates and see what is happening at that moment.
After the data is corelated , then have a wireless software programmer look at those time periods and attempt to make some wireless software changes in an attempt to reduce to a bare minimum all of the dead silent wireless TX & RX system where the wireless network is saturated.
As an old Electronics Engineer, I know getting a graph of TX & RX and dead silent periods should be fairly easy and simple to do.
However, It might require a good wireless software engineer to figure out what part of the wireless protocol/software was responsible for dead-air & 6-Meg rates and check/review/modify the wireless software code in attempts to acheive faster client throughput during wireless saturation.
Also - perform the same testing with a Point-to-Point (AP to Clinet) and perform the same procedures to improve customer wireless thorughput.
I am willing to bet , there is a superising amount of dead-air and 6-Meg connection rates , and other possible things that can be discovered and improved on to improbe throughput
n21roadie - Re: I would also ask does the 6 Mbit limit also apply to ethernet and fibre connections ?
I doubt it - they are totally different drivers & protocols.
However … Ethernet and Fiber each also have their own additional things going on for initial link-connect-speeds , advertised rate capabilities , mdix , POE , along with other things.
Also - there is a big huge difference between 10/100 meg copper Ethernet cable wireing and Gig Ethernet wireing. Gig Ethernet actually is supposed to use 8-wires and 10/100 Meg Ethernet is really using only 4-wires in an Ethernet cable.
And - unlike typical Microwave (including all Mikrotik wireless cards) , Ethernet & Fiber can run Full-Duplex (send and receive at the same time). Microwave is always half-duplex , and can only send -or- receive one at time and never both at the same time. Sometimes it switches between send and receive so fast that it might behave like Full-Duplex but it is only Half-Duplex. Because wireless is only Half-Duplex , there are additional timing related protocols to make wireless work. A wireless AP can’t properly send data to a Client while the Client is also sending to the AP at the exact same moment in time. This is where Mikrotik has created two additional wireless protocols (nstream an nv2). Both address different issues with the way wireless timing protocols operate and both have their own strengths and weaknesses. FYI - the Mikrotik nv2 protocol is actually is a properitery TDMA protocol used only by Mikrotik. The TDMA/nv2 timing is actually a hardware feature built into the Atheros wirless chipsets. Mikrotik nv2 is simply setting some registers/switches/configs in the Atheros chipset and then using some drivers to talk to the now-re-configured Atheros wireless chipset. TDMA has been around for a very long time - way way way longer than Mikrotik has been around. Mikrotik nv2 is just a Mikrotik protocol that configures/uses the TDMA capabilities of the wireless chipset.
With wireless , timing is critical to acheive throughput.
TDMA is a Half-Duplex timeslot protocol where all devices have defined periods in time where they can transmit
nstream is an AP polling protocol where the AP says to each client you can now transmit
802.11 wireless is more of a free-fall where it is possible to have multiple clients transmitting at the same time , which then can result in a small brief moment where data was lost. When data is lost using 802.11 wireless , then Random-Early-Detection (RED) kicks in and everything stops , waits a random amount of time and then begins again.
FYI - TCP-IP rate limiting / bandwidth queues actually uses the RED protocol to maintain communication speeds
