Hi i having a big problem trying to install mikrotik on new intel boards
i tested in two new 946g and a 945 gnt and i have problems even using IDE disks.. tryied 4 of them
i can install the mikrotik but after install it doesnt boot, the motherboard tells that theres no bootable device then get those hard drives and put in a cheap and old mobo, pccchips and mikrotik boot up!
alreay tryied mikrotik on a sata with legacy mode enabled and no go!
n1 can help or already have those problems and fixed it?
We have also a problem here with an Intel board (D945GTP).
System only boots with 3.0b6, otherwise the onboard ide controller is not recognized (seems to be so).
We plugged in an RB44, but only one port appears in “interfaces”
We plugged in a second RB44, same effect.
We plugged the board in to another router, all4 ports visible
We plugged in a DL-580 (D-Link 4 Port), 2 Ports are visible.
But in System/Ressources/PCI there are 4 devices listed.
We disabled all “unused” devices in the bios → no effect.
We updated the bios to the latest version → no effect
Intel removed the PATA controller from the 945/946 chipset series. The PATA port on the motherboard is put there by the motherboard vendor, utilizing an off-chipset onboard IDE controller.
The problem you are having is probably that the chip on your motherboard isn’t recognized by the generic IDE driver.
