mikrotik on other devices?
Hi.
i use mikrotik, only software..
i would like to ask you if you know router (no routerboard with mikrotik pre-installed), like d-link, linksys or others where I can put mikrotik software..
i need a gsm/gprs router with mikrotik…
i can’ use a pc because this installation will be done al 2.000 mt on a mountain without current electrical worker, but only a solar panel..
i don’t know where find it.
thanks
I’ve been wondering the same thing -
I’ve found a router that has a similar processor architecture to the Mikrotik routerboards, so in the coming week I’m going to see if I can do a remote install on that router.
http://www.acconet.co.za/detail.php?cat=93&sub=90&id=5074
This is the router that I’ll be trying.
I’ll post my progress here.
-Krige
thanks.
i will wait for your answer.
bye
The Acconet Router WR-2415/EXT
Based on a Realtek8186 / RTL8225 Chipset
you can´t use with Mikrotik RouterOS
Ag no :frowning:
Oh well - I’ll hack away at it anyway.
Any suggestions for routers?
-K
You can use the old Wrap board (http://www.pcengines.ch/wrap.htm) or
were to the successors ALIX board on the market are.
(http://www.pcengines.ch/alix.htm)
or you use equal a RB 532/RB 333 cost nearly the same and the Level4 license are already inclusive.
Cool, thanks - I guess there’s little point in this exercise other than to satisfy my own inquisitive nature. :slight_smile:
Thanks for the information!
Appreciated.
This was a good question. I’d like to flash all my leftover devices to MT. Imagine these Karlnet devices put to good use…
