Hello Dear!
my isp is not doing anything to help me.
can you please help me to fix this problem from my site?
a possibility to force the traffic to pass through the 10.70.70.1
Regards
Hello Dear!
Regards
ALex,
We have the same problem.
We also need to reboot every 24 hours.
hi
it is may be happen for your internet banthwith.
if your internet bandwith is full,then your ping time is timeout.
This happen even when less than 10% is used
We have a good fiber (direct) inter connect with plenty spare capacity. Far more than we can use.
Our band width is not the problem. In our case the wireless cardss seem to looase response on the 386 if you then reboot all is 100%
Somethimes I also have something like you … and I discover that is problem in swich … my 3-com gigabit swich sometime need to be reboot ![]()
When this hapening try to turn of - on swich
I have a auto reboot on the system to reboot the 386 every X hours that works ok.
It is a pity of this.
What would still be a 1000% improvement is a hardware dead man timer toggled by the software ( for reset) .
We find under certain issues when the router hangs it must be physically rebooted.
If mtik would have added this dead man timer in the software I can assure you the system would be in a different class.
