Mikrotik Open VPN connected without access to the lan
hello guys,
i already created a mikrotik open vopn server as bellow but i can’t access the lan on open vpn i tried a firewall rule and alo proxy-arp it didnt work any help ?
/certificate
add name=CA common-name=CA days-valid=3650 key-usage=key-cert-sign,crl-sign
sign CA ca-crl-host=184.142.40.170
:delay 5
set CA trusted=yes
/certificate
add name=server common-name=server days-valid=3650 key-usage=digital-signature,tls-server,key-encipherment
sign server ca=CA
:delay 5
/certificate
add name=client common-name=client days-valid=3650 key-usage=tls-client
sign client ca=CA
:delay 5
export-certificate CA file-name=CA
export-certificate client export-passphrase=12345678 file-name=client
:delay 5
/ip/pool add name=openvpn range=10.10.5.2-10.10.5.20
:delay 2
/ppp profile add name=ovpn local-address=10.10.5.1 remote-address=openvpn
:delay 2
/ppp secret add name=ants password=P@ssw0rd profile=ovpn
:delay 2
/interface ovpn-server server set enabled=yes certificate=server default-profile=ovpn
:delay 2
/interface ovpn-server server export-client-configuration server-address=194.126.17.238 ca-certificate=CA.crt clie
nt-certificate=client.crt client-cert-key=client.key
/ip firewall nat add chain=srcnat src-address=10.10.5.0/24 action=masquerade
Seems rather complicated compared to wireguard.
