Mikrotik OpenVPN behind external router ?
Hello
I have a main router D-link that I’m forword port 1194 to a mkirotik router (that I wnat to use as an OpenVPN server for my local network)
the Mikroitk is used sa a bridge (wlan+ethernet)
add fast-forward=no name=bridge1
//interface bridge port
add bridge=bridge1 interface=wlan1
add bridge=bridge1 hw=no interface=ether4
add bridge=bridge1 hw=no interface=ether3
add bridge=bridge1 hw=no interface=ether2
add address=10.0.0.2/24 interface=bridge1 network=10.0.0.0
add action=accept chain=input comment="Ping to Router" protocol=icmp
add action=accept chain=input comment="Allow OpenVPN" dst-port=1194 protocol=tcp
/ppp secret
add local-address=10.0.0.2 name=Phone password=********* remote-address=10.0.0.221 service=ovpn
/ppp profile
add name=OpenVPN-Profile only-one=yes use-encryption=yes
/interface ovpn-server server
set auth=sha1 certificate=server-certificate cipher=aes128,aes192,aes256 enabled=yes require-client-certificate=yes
I can see the phone is connected on the Mikrotik and get 10.0.0.221
but I have no Ping to the local netwrok (10.0.0.1-10)
the openvpn config file route is
10.0.0.0 255.255.255.0
and when I traceroute from the phone I can see it’s sending the Mikrotik
do I need to change\add anything else ?
the network is setup that the D-link is the router\ Default gateway (10.0.0.1)
can this be the reason?
…as far as I know, you will need a dedicated transfer network for the ovpn connection, not just the same IPs from your local LAN for clients.
See: https://help.mikrotik.com/docs/display/ROS/OpenVPN#OpenVPN-OVPNServer
Also note the hint at the bottom of that page:
Since RouterOS does not support route-push you need to add manually which networks you want to access over the tunnel.
but the Mikrotik is not hte client
it’s the server
so maybe I didn’t understand - what do I need to do ?
I need to add client open vpn on the server itself? so it will connect to itself?
****UPDATE
after “playing” with all kind of masquerade rules
I did this
add action=masquerade chain=srcnat dst-address=10.0.0.0/24 src-address=10.0.0.221
and it’s working
I have only 1 devices for my Openvpn - so it’s a good solution for me now
I will try to chane the Openvpn address to another netwrok - and see if it’s also working
You can also set arp=proxy-arp for bridge1, and then you won’t need masquerade.
