Anyone have tried to use Mikrotik as OpenVPN Client with OpenVPN Server from www.strongvpn.com ? I tried many times and Mikrotik could not connect to their server.
Please solve this.
Regards
Please solve this.
Regards
post your openvpn configuration
I just earased all config yesterday. But I will make it again.
OpenVPN from strongvpn used UDP. Does Mikrotik support it ?
I use ROS v3.24.
No, it supports only TCP.
I am chatting with their support now. And he said can switch OpenVPN Server to TCP.
I will make new config now and will let you know soon.
Also LZO compression is not supported, and requires username and password authentications
They already switch my OpenVPN to TCP port.
Here files I got from them:
ta.key
ovpn007.ovpn
ovpn007.key
ovpn007.crt
install-ovpn007.sh
install-ovpn007.cmd
ca.crt
Then I open those files with notepad to see what inside. Here is inside those files:
ta.key
# 2048 bit OpenVPN static key
-----BEGIN OpenVPN Static key V1-----
68001c583f5712868f5616b1c69de9d5
c4eee17436c3f4f8986d5e62bb55e782
1342c2e7ad1debcecaea253acc23d5e9
blablablablablablablablablablablablabla
-----END OpenVPN Static key V1-----
ovpn007.ovpn
remote 74.125.xxx.xxx 1201
proto tcp
ca ca.crt
cert ovpn007.crt
key ovpn007.key
tls-auth ta.key 1
client
dev tun007
resolv-retry infinite
nobind
persist-key
persist-tun
;http-proxy-retry # retry on connection failures
;http-proxy [proxy server] [proxy port #]
verb 4
mute 5
tun-mtu 1500
fragment 1300
mssfix 1450
ovpn007.key
-----BEGIN RSA PRIVATE KEY-----
MIICXQIBAAKBgQC3w4ydbPXl4Evv1U/RA1DOr9fBD+vvDsrpMvgGsyuYfE+Zjhs/
blablablablablablablablablablablablablablablablablablablablablablablablabla
-----END RSA PRIVATE KEY-----
ovpn007.crt
Certificate:
Data:
Version: 3 (0x2)
Serial Number: 2 (0x2)
Signature Algorithm: md5WithRSAEncryption
Issuer: C=US, ST=NA, L=San-Francisco, O=oakweb.com, CN=ovpn007/emailAddress=techies@xxxx.com
Validity
Not Before: Sep 13 14:49:05 2008 GMT
Not After : Sep 11 14:49:05 2018 GMT
Subject: C=US, ST=NA, O=oakweb.com, CN=ovpn007/emailAddress=techies@xxxxxxxxxx.com
Subject Public Key Info:
Public Key Algorithm: rsaEncryption
RSA Public Key: (1024 bit)
Modulus (1024 bit):
00:b7:c3:8c:9d:6c:f5:e5:e0:4b:ef:d5:4f:d1:03:
xx:xx:xx:xx:xxxx:xx:xx:xx:xxxx:xx:xx:xx:xxxx:xx:
xx:xx:xx:xx:xx
Exponent: 65537 (0x10001)
X509v3 extensions:
X509v3 Basic Constraints:
CA:FALSE
Netscape Comment:
OpenSSL Generated Certificate
X509v3 Subject Key Identifier:
D4:6D:97:95:9C:48:BF:8D:D6:CB:BE:63:20:ED:29:5E:5E:2A:B6:D2
X509v3 Authority Key Identifier:
keyid:17:26:8C:D7:F7:D2:EC:86:6E:1C:74:41:7A:38:F1:FA:F1:3C:9E:F7
DirName:/C=US/ST=NA/L=San-Francisco/O=oakweb.com/CN=ovpn007/emailAddress=techies@xxxxxxxxxx.com
serial:F5:5A:C4:BA:C8:A5:5F:8D
27:14:c8:7c:d7:11:27:74:4c:4a:2b:0a:f6:d7:5e:2a:b7:81:
xx:xx:xx:xx:xxxx:xx:xx:xx:xxxx:xx:xx:xx:xxxx:xx:xx:xx:xx:
xx:xx
-----BEGIN CERTIFICATE-----
MIIDhDCCAu2gAwIBAgIBAjANBgkqhkiG9w0BAQQFADCBhTELMAkGA1UEBhMCVVMx
blablablablablablablablablablablablablablablablablablablablablablablablablablablabla
blablablablablablablablablablablablablablablablablablablablablablablablablablabla==
-----END CERTIFICATE-----
install-ovpn007.sh
#!/bin/sh
if [ ! -e /etc/openvpn ]; then mkdir -p /etc/openvpn; fi
cp ovpn007.ovpn /etc/openvpn/ovpn007.conf
cp ca.crt ovpn007.crt ovpn007.key ta.key /etc/openvpn
install-ovpn007.cmd
@echo off
copy /a ovpn007.ovpn ovpn007.key ovpn007.crt ta.key ca.crt "C:\Program Files\OpenVPN\config"
ca.crt
MIIDeDCCAuGgAwIBAgIJAPVaxLrIpV+NMA0GCSqGSIb3DQEBBQUAMIGFMQswCQYD
Does this OpenVPN support with Mikrotik ?
Ok, thanks for your help.
YUJOBIKA, any success with openvpn connection to strongvpn.com ?
Hi, never success ![]()
So I am using normal VPN only.
I once posted an issue in regard to vpn connection.
In my case, i could establish a connection to a vpn server with PPTP. But my concern was how my client could connect to the internet through the vpn instead of direction connection to the internet,
Good solution should be posted here please.
Is ur mikrotik connected a vpn server?
andis:
Hi, never success
Is ur mikrotik connected to a vpn server?
