mikrotik ospf and quagga via openvpn
Hello!
I’m trying to set up ospf between mikrotik and linux quagga, but I got in mikrotik logs next message:
12:57:33 route,ospf,debug RECV: Hello ← 192.168.10.98 on (192.168.10.1)
12:57:33 route,ospf,info Discarding Hello packet: mismatch in network mask
12:57:33 route,ospf,info mine=255.255.255.255
12:57:33 route,ospf,info remote=0.0.0.0
12:57:33 route,ospf,info source=192.168.10.98
192.168.10.1 is mikrotik openvpn interface
192.168.10.98 is linux quagga
quagga config:
ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP qlen 1000
link/ether 1c:6f:65:ca:00:d7 brd ff:ff:ff:ff:ff:ff
inet 192.168.146.187/24 brd 192.168.146.255 scope global eth0
3: tun0: <POINTOPOINT,MULTICAST,NOARP,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UNKNOWN qlen 100
link/none
inet 192.168.10.98 peer 192.168.10.1/32 scope global tun0
cat ospfd.conf
! Zebra configuration saved from vty
!   2014/07/03 15:05:08
hostname ospfd
password ***
log file /var/log/ospf.log
debug ospf packet all detail
interface eth0
interface lo
interface tun0
router ospf
 ospf router-id 192.168.10.100
 network 192.168.146.0/24 area 0.0.0.0
 network 192.168.10.0/24 area 0.0.0.0
line vty
mikrotik:
/routing ospf instance
set [ find default=yes ] router-id=192.168.10.1
/routing ospf network
add area=backbone network=172.16.0.0/22
add area=backbone network=192.168.10.0/24
add address=172.16.1.9/22 interface=LAN network=172.16.0.0
add address=xxxxx/30 interface=WAN network=xxxxxx
Please help, what’s wrong?
PS. quagga can see neighbor, but mikrotik can’t:
ospfd# show ip ospf neighbor d
Neighbor 192.168.10.1, interface address 192.168.10.1
In the area 0.0.0.0 via interface tun0
Neighbor priority is 1, State is Init, 1 state changes
Most recent state change statistics:
Progressive change 7m41s ago
DR is 192.168.10.1, BDR is 0.0.0.0
Options 0 |-|-|-|-|-|-|
Dead timer due in 38.209s
Database Summary List 0
Link State Request List 0
Link State Retransmission List 0
Thread Inactivity Timer on
Thread Database Description Retransmision off
Thread Link State Request Retransmission off
Thread Link State Update Retransmission off
Please cek your address in for both router, Your end is a /32 while the remote end is a /0.
thank you for answer,
both have /32 mask:
[main-router] > ip address p
ADDRESS NETWORK INTERFACE
0 172.16.1.9/22 172.16.0.0 LAN
2 D > 192.168.10.1/32 > 192.168.10.98
akam # ifconfig
tun0: flags=4305<UP,POINTOPOINT,RUNNING,NOARP,MULTICAST> mtu 1500
inet 192.168.10.98 > netmask 255.255.255.255 > destination 192.168.10.1
unspec 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00 txqueuelen 100 (UNSPEC)
RX packets 2854 bytes 182032 (177.7 KiB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 2737 bytes 183064 (178.7 KiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
Try /30 on both ends.
i think this is related to Your tunnel setup.
To solve this problem You should select point-to-point network type on the Mikortik’s ospf interface configuration.
Best regards,
Rod Barbosa
