Iam strugling to make this scheme work, which commands should I use? How to make Areas ping each other? and how to run lacp protocol, now I am using only one wire between routers.
You can use all 3 routers in the same area. In OSPF you will make a simple balance between these links.
My task is to connect routers from diffrent areas
I have 3 routers connnected by OSPF protocol, 1, 2 ir 3. Between 1 and 2 there is Area0 backbone, between 1 and 2 there is Area2, and between 2 and 3 there is Area1. Iam pinging between 1 and 2 and its possible, but I cant ping between 1 and 2 or between 2 and 3, is it good? Or should I get ping between 1 and 2 or 2 and 3. Thanks for the answers..
–kitamanis
