Mikrotik when are you going to be coming out with a switch is POE output on all ports? I want my whole network to use this product. Wasn’t there going to be a RB750up product that would do this? The main question is, will this come out this year?
I found the new product:
RB750UP
- Same as regular RB750
- USB port
- 24V Power Output on four ports
- Controllable PoE out
- SNMP support
- Voltage and current monitors
- Can power PoE capable devices
- Less cables and PoE injectors
When is this product purchasable?
Where did you see it? Sounds very interesting, I can use these…
If you want it for now and cheap,
you can easily modify a RB750 to output power on ports 2 to 5.
It just takes about
- 15 minutes time
- a solding iron
- solder and
- 15cm of solid wire.
Thanks I heard about that. I just want mikrotik to build me this product.
Mikrotik is this product coming out this month?
September
Which year? ![]()
we want to pass all tests and make certificates for it, so sorry, there have been delays.
RB750UP
- Same as regular RB750 - YES
- USB port - YES
- 24V Power Output on four ports - YES
- Controllable PoE out - YES
- SNMP support - NOT YET
- Voltage and current monitors - you see incoming voltage in the board, not output
- Can power PoE capable devices - YES
- Less cables and PoE injectors - YES
When is this product purchasable? - Hopefully this year, sadly, not September ![]()
He wrote the 5th of October! ![]()
what?
IMHO, better delayed than with HW problems.
WirelessRudy:
janisk:
what?
It’s a funny remark!
Stating the 5th of October something will not be available in September is an understatement… I find it funny! Like asking “what year” is funny for the same reason…
Yeah I dont want issues. Mikrotik can take long as they want. ![]()
OK, but you wrote it wrong, from your post I understood that somebody had promised the product in October 5th. Sorry, it’s clear now.
Any new announcements about release of this product?
read above:
m4rk0:
read above:
Are we there yet
any word on these?
I back ordered about 20 of these. When about am I getting them?
