MIKROTIK POWERBOX ALL PORTS ARE BRIDGE
I need to have all ports in bridge mode. Do I have to make one port WAN and others LAN - then create the Bridge? Or should I make a WAN bridge for all ports? I am using powerbox to help power up radios on roof for client. One radio brings the Internet to powerbox, and then the POE in port 1 is plugged into the customer’s switch. We are powering up the Powerbox over POE.
No ports need DHCP
Thanks.
As you’re using powerbox as PoE switch, all ports should be bridged. Move DHCP client to bridge if you want powerbox to receive IP address from main router (you can manage powerbox using winbox without powerbox having IP address though).
If all interfaces are bridged, then WAN or LAN has no meaning for the traffic handling among them. Being member of the LAN or WAN interface list is an attribute of the bridge. Ports (slave interfaces) follow this setting of the bridge as the L3 packet handling is on the bridge, not on the ports(interfaces). The same for the IP address.
The bridge being member of the LAN or WAN interface list will affect the allowed traffic to and from the router, when the default FW is used.(!) … access and mangle rules, SRC_NAT, discovery protocols, MAC services, …
Thank you all
