Hi. Use Mikrotik Hotspot with DMA Radius to authenticate and disconnect users. Works good. Also have some AP’s set up as PPPoE server with user connecting to AP using PPPoE client to authenticate with radius. Works good, but prolem is, radius does not disconnect PPPoE client. If i do this manual, the incoming radius bad count in the AP acting as PPPoE server increase by 3. Just can’t seem to find the problem, net even with my friend Google.
Any suggestions would be appreciated.
Use disconnection method to remote in DMA. ALSO, use api.
Hi. Thanks for the feedback, but found the problem. One of the router’s passing through was incorrectly set up with masquerading. This caused the PPPoE server to drop the request because it appeared not to originate from the radius server ip.
