Mikrotik PPPOE server, wireless router as PPPOE dialer/client
hey master! hopefully i got the answer from this forum. firstly i want to say sorry if i open this topic in wrong section,
i need help from you guys. really appreciate if you guys help me to solve this.
i already setup mikrotik as pppoe server.
i try to connect using windows dialer as client. the connection seem working. and the pc also can use the internet.
but when i tried to setup Asus e1700 as client, it wont connect. nothing show at linksys web configuration status page.
it make me stressed. i dont know how to solve it. :question: :question: :question: :question:
anybody here got some problem like this? and how to solve it? many thanks if you guys can help me. :smiley: :smiley: :smiley: :smiley:
my best guess would be authentication, encryption or something in your PPP profile does not match that of the ASUS.
sorry cannot be more specific without actualy seeing the device config
ok, i will screen caps the setting for us to see.
but now the device is not in my hand. will do it asap. thanks m8. :slight_smile:
m8, i got connect the PPPOE using my TP-LINK brand router also, but the ASUS and Linksys router cant.
Is it my linksys or Asus or my mikrotik setting need to check? im already confuse. but im sure my Asus and Linksys router configured corretly.
do u have an idea which part need to check?
