Hello, I am hoping someone can find the error in my ways on this.
I setup an RB750 as a gateway router with a firewall/nat/pptp server per the wiki articles. I thought I had it working but it appears that not all is working. I can ping the devices on on the local lan, I can ftp to the devices that support it, but i cannot connect to a NAS that is serving files for the remote users. I type in windows explorer \192.168.1.200 (NAS) and windows reports that it cannot contact the device. Ping confirms i have connectivity though! I suspect it has something to do with my firewall and nat, as i don’t know exactly what i am doing with all of it. I have included a print of these settings.
If there is any help that someone can give me to straighten this out?
/ip address print
ADDRESS NETWORK BROADCAST INTERFACE
0 ;;; default configuration
192.168.1.1/24 192.168.1.0 192.168.1.255 ether2-local-master
1 D 66.xxx.xxx.xxx/21 66.xxx.xxx.xxx 66.xxx.xxx.xxx ether1-gateway
2 D 192.168.1.1/32 192.168.88.1 0.0.0.0
/ip route print
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme,
DST-ADDRESS PREF-SRC GATEWAY-STATE GATEWAY DISTANCE INTERFACE
0 ADS 0.0.0.0/0 reachable 66.xxx.xxx.xxx 0 ether1-gateway
1 ADC 66.xxx.xxx.xxx/21 66.xxx.xxx.xxx 0 ether1-gateway
2 ADC 192.168.1.0/24 192.168.1.1 0 ether2-local-master
3 A S 192.168.88.0/24 reachable 192.168.88.1 1
4 ADC 192.168.88.1/32 192.168.1.1 0
add action=accept chain=input comment=“default configuration” disabled=yes protocol=icmp
add action=accept chain=input comment=“default configuration” connection-state=established disabled=yes in-interface=ether1-gateway
add action=accept chain=input comment=“default configuration” connection-state=related disabled=yes in-interface=ether1-gateway
add action=drop chain=input comment=“default configuration” disabled=yes in-interface=ether1-gateway
add action=accept chain=forward comment=“allow established connections” connection-state=established disabled=no
add action=accept chain=forward comment=“allow related connections” connection-state=related disabled=no
add action=drop chain=forward comment=“drop invalid connections” connection-state=invalid disabled=no
add action=drop chain=virus comment=“Drop Blaster Worm” disabled=no dst-port=135-139 protocol=tcp
add action=drop chain=virus comment=“Drop Messenger Worm” disabled=no dst-port=135-139 protocol=udp
add action=drop chain=virus comment=“Drop Blaster Worm” disabled=no dst-port=445 protocol=tcp
add action=drop chain=virus comment=“Drop Blaster Worm” disabled=no dst-port=445 protocol=udp
add action=drop chain=virus comment=________ disabled=no dst-port=593 protocol=tcp
add action=drop chain=virus comment=________ disabled=no dst-port=1024-1030 protocol=tcp
add action=drop chain=virus comment=“Drop MyDoom” disabled=no dst-port=1080 protocol=tcp
add action=drop chain=virus comment=________ disabled=no dst-port=1214 protocol=tcp
add action=drop chain=virus comment=“ndm requester” disabled=no dst-port=1363 protocol=tcp
add action=drop chain=virus comment=“ndm server” disabled=no dst-port=1364 protocol=tcp
add action=drop chain=virus comment=“screen cast” disabled=no dst-port=1368 protocol=tcp
add action=drop chain=virus comment=hromgrafx disabled=no dst-port=1373 protocol=tcp
add action=drop chain=virus comment=cichlid disabled=no dst-port=1377 protocol=tcp
add action=drop chain=virus comment=Worm disabled=no dst-port=1433-1434 protocol=tcp
add action=drop chain=virus comment=“Bagle Virus” disabled=no dst-port=2745 protocol=tcp
add action=drop chain=virus comment=“Drop Dumaru.Y” disabled=no dst-port=2283 protocol=tcp
add action=drop chain=virus comment=“Drop Beagle” disabled=no dst-port=2535 protocol=tcp
add action=drop chain=virus comment=“Drop Beagle.C-K” disabled=no dst-port=2745 protocol=tcp
add action=drop chain=virus comment=“Drop MyDoom” disabled=no dst-port=3127-3128 protocol=tcp
add action=drop chain=virus comment=“Drop Backdoor OptixPro” disabled=no dst-port=3410 protocol=tcp
add action=drop chain=virus comment=Worm disabled=no dst-port=4444 protocol=tcp
add action=drop chain=virus comment=Worm disabled=no dst-port=4444 protocol=udp
add action=drop chain=virus comment=“Drop Sasser” disabled=no dst-port=5554 protocol=tcp
add action=drop chain=virus comment=“Drop Beagle.B” disabled=no dst-port=8866 protocol=tcp
add action=drop chain=virus comment=“Drop Dabber.A-B” disabled=no dst-port=9898 protocol=tcp
add action=drop chain=virus comment=“Drop Dumaru.Y” disabled=no dst-port=10000 protocol=tcp
add action=drop chain=virus comment=“Drop MyDoom.B” disabled=no dst-port=10080 protocol=tcp
add action=drop chain=virus comment=“Drop NetBus” disabled=no dst-port=12345 protocol=tcp
add action=drop chain=virus comment=“Drop Kuang2” disabled=no dst-port=17300 protocol=tcp
add action=drop chain=virus comment=“Drop SubSeven” disabled=no dst-port=27374 protocol=tcp
add action=drop chain=virus comment=“Drop PhatBot, Agobot, Gaobot” disabled=no dst-port=65506 protocol=tcp
add action=jump chain=forward comment=“jump to the virus chain” disabled=no jump-target=virus
add action=accept chain=forward comment=“Allow HTTP” disabled=no dst-port=80 protocol=tcp
add action=accept chain=forward comment=“Allow SMTP” disabled=no dst-port=25 protocol=tcp
add action=accept chain=forward comment=“allow TCP” disabled=no protocol=tcp
add action=accept chain=forward comment=“allow ping” disabled=no protocol=icmp
add action=accept chain=forward comment=“allow udp” disabled=no protocol=udp
add action=accept chain=forward comment=“Allow Winbox” disabled=no dst-port=8291 protocol=tcp
add action=accept chain=forward comment=“Allow PPTP” disabled=no dst-port=1723 protocol=tcp
add action=accept chain=forward comment=“Allow GRE” disabled=no dst-port=47 protocol=tcp
add action=drop chain=forward comment=“drop everything else” disabled=no
add action=masquerade chain=srcnat comment=“default configuration” disabled=no out-interface=ether1-gateway
add action=dst-nat chain=dstnat comment=“” disabled=no dst-address=0.0.0.0 dst-port=1723 protocol=tcp to-addresses=192.168.1.1 to-ports=1723
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061
set pptp disabled=no
Thanks for any help. Also, I added the dst-address=0.0.0.0 in the nat so that a user on the lan is able to contact another remote site via vpn.
