mikrotik pptp client problem
i have configure mikrotik pptp server then i tested with PC win XP it’s work. i can dial to pptp server but when i make pptp client at other mikrotik server it’s hard to make connection. please advice
need a little more info.
one thing on a MT-MT pptp connection you need to put routes between them .
at Mikrotik pptp client hard to dial pptp server. i have also tested l2tp and it work ok. is there something i missed ? one more question, what port that l2tp connection used ?
it seems ok with dial up, i don’t have problems with it.
when MT is client.
but it is truth, that we should be careful with routes, there might be some problems.
l2tp uses udp protocol.
when establishing connetction it takes 1701 udp protocol.
but after it further traffic uses available udp port.
