Mikrotik Pro app question (android)
Hello Friends!
I use the RB SXT G-5HPacD r2 for system remote in concert audio with Mikrotik app on Android.
Is it possible to display the channels/frequencies available for the currently configured country? (Austria & Hungary)
RouterOS: v 6.49.17
device:RB SXT G-5HPacD r2
Thank You!
Sure, this can be accomplished by use of cli.
Give me a second for the correct command...
Here it is:
/interface wireless info country-info [country name]
OR
/interface wireless info country-info country=[country name]
Don't use the brackets.
Thanks for quick respond! Can I use this command line even if the router is set to Austria but I want to query the Czech Republic, for example?
Yes!!
AI-speak
Thank You!
Just I-speak...
