Mikrotik Pro Mobile App "Run after Reset" broken?
Using same .rsc script on a config and reboot (82 lines, nothing too complicated)
No Default Configuration
Run after Reset…..
Running via Winbox on PC behaves as expected and works.
Running Via Mikrotik Pro Mobile app on android DOES NOT apply the config file when using ;
(Main Menu Screen)Other Settings\Reset Configuration or ;
(Top Left Main Menu Pulldown)System\Reset Configuration
(automatic finding and filling of the .rsc file is hit and miss here too)
Running via Mikrotik Pro mobile app under (Top Left Main Menu Pulldown)“New Terminal”
/system reset-configuration no-defaults=yes skip-backup=yes run-after-reset=portableconfig.rsc
DOES WORK
(issues with unable to paste that line however and has to be entered manually so slower)
:delay 15s makes no difference
portableconfig.rsc saved at / and /flash/
solved it by putting the file in BOTH of the fields “Run After Reset’ in the app ( portableconfig.rsc )
:delay 15s was NOT necessary
